LH Engine Mount Stuck
All things Altima Coupe.
inastupor
Car: 2008 Nissan Altima
Hey everybody. So I went out to do what I thought was gonna be an easy 45mins worth of work. While attempting to change the LH engine mount on a 2008 Altima 2.4L M/T coupe I discovered that the bolt coming up from the bracket was actually stuck. If I had to guess, its seized up in the sleeve of the mount. I thought the weight of the engine would pull it loose, but jacking the transmission up/down has no effect on the bolt (doesnt go down when lowering the jack). Tomorrow I plan on removing the mount bracket (both) and see if I can separate them...........unless someone here can suggest a better/easier way to get that bracket unstuck from the mount. Just so you know I'm an beginner. I know a bit more than the basics, but am still just starting out so have a bit of patience if I say/do/ask something stupid. Thanks guys. -A
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You're probably right that the stud is seized to the bushing. Take the lower bracket (5) loose from the transmission. Don't worry about the transmission falling out, it will drop a few inches but the other mounts will hold it. Put the nut back on so you won't hurt the threads, and knock the stud loose with a hammer. If that doesn't do it, you can try concentrating the blows with a punch. A healthy dose of WD40 left to soak overnight may help a lot. In a worst case, you can take the support (6) loose to get the whole shebang out of the car and attack it on the workbench.
inastupor
Thanks VStar650CL so much for the quick reply and giving me a plan of attack. I'm gonna to spray it down a bit more and leave it be till the morning. I'll repost with the results. -A
