LF: KA24DE engine harness
martin
I know this isn't the classifids, but I had no luck there. I figured someone here must have one lying around after a swap.
Thanks...Martin.
unfrgivn
I have an almost intact one lying right next to me... Everything is there except for the two plugs by the battery that get cut off during the swap. The main plug and the rest of the harness is intact. I will let it go pretty cheap if you're interested.
BuudWeizErr
I know someone who has a complete KAE harness that is only missing the dash plug. I can tell you who to call if you want it.
martin
unfrgivn wrote:I have an almost intact one lying right next to me... Everything is there except for the two plugs by the battery that get cut off during the swap. The main plug and the rest of the harness is intact. I will let it go pretty cheap if you're interested.
I'm sure I can find those plugs, and I can solder! I'll take them both for "pretty cheap" ;-)
Name your price!
Thanks...Martin.
martin
BuudWeizErr wrote:I know someone who has a complete KAE harness that is only missing the dash plug. I can tell you who to call if you want it.
Thanks Bud.. If the above falls through I'll take you up on that.
-Martin.
