LEXUS WHEELS WILL THEY FIT ?
TRANCEBOY
Car: Rogue SL
SIZE IS
Tire Type: All-Season Passenger Section Width: 235
Rim Brand: Factory, OEM Rim Material: Alloy
Tire Brand: Michelin Number of Bolts: 5
Condition: New Bolt Pattern(s) (millimeters): 5x114.3
Car Type: Passenger/Performance Rim Structure: One Piece
Aspect Ratio: 55 Rim Diameter (inches): 19
Load Index: 101 Rim Width: 7.5
I CANT FIGURE HOW TO ADD PICS
THEY ARE THE 2010 WHEELS ON THE RX350 MODEL
Leo2005
Are you talking about regular 18" or sport tuned 19"? They both may fit but the offset might be different. Also the original tire may not fit and you will have to get low profile
Leo2005
okay. just looked at them without big problems except the tire. Both 18" and 19" showed me diameter over 27" but in this case you will end up touching the tire with the strut. There's not much space in Rogue...this is not a murano. So unless you get a set of tires like 235 or 245 with height of 35 to 45 then you should be fine.
TRANCEBOY
Car: Rogue SL
They are the 19 that come one the new lexus rx350
if i can figure how to add pics ill post a pic.
does anyone know how to photoshop >?
check the specs on the top tire says 235 in width
is that what you mean ??
sorry im not to familiar with this wheel stuff
philipa_240sx
TRANCEBOY wrote:sorry im not to familiar with this wheel stuff
Read here:
http://www.tirerack.com/tires/tiretech/ ... p?techid=7
and here:
aftermarket-wheel-tire-fitment-chart-t293478.html
Return to “Rogue Forum”
