Thanks RBsileighty! You probably spoke with Daryl at Turbonetics, I talked to them today about the recomendations for proper turbo sizing and set em' straight haha. Yes the 62-1 flows slightly more, it has the same size exducer, but a slighty larger inducer diameter, but it shares the same contour profile of the 60-1 wheel. Either turbo on a RB20, would spool quite late, you can't guess an exact number, because there are so many factors involved with spool up, such as what gear you are in, load, ecu tuning, exhaust diameter, etc. If I had to guesstimate when it would make full boost, I would say around 4500-5000rpm. That also depends on the turbine wheel size and turbine housing A/R.
Exactly WDRacing, E50 is a perfect size for a daily driver and weekend racer, I looked at the compressor maps and thats why I went with the E50. E57 wouldn't be too bad either. I don't like E54, its a crappy trim, look at the compressor map, its efficiency range is tiny.
rbsileighty wrote:Great info Mark. I really am not sure who I spoke with on the phone. He spoke like he was from the north east with a deep voice if I remember correctly.
I was really surprised to hear the 60 and 62 were basically the same, except the 62 flowed more. However, I figured this guy works there and not me, so I guess he knows what he's talking about. Is it true these two flow the same? When would you expect to see boost running either of these on a mildly and/or heavy tuned RB20 (the question is open to you as well Chris)?
Always nice to have insiders like you on the boards Mark.
