DrifterProdigy85 »
https://forums.nicoclub.com/drifterprodigy85-u30257.html
Wed Dec 27, 2006 6:04 pm
I set Fuel Pressure at 45psi. Going too high or low will not allow the injectors to function properly. Dont recommend going below 40psi or above 50psi. If your gonna tune with the SAFCII, using the stock ECU and SAFCII with 550cc injectors. Id probably lean out 20% to start and work from there. Keep at stock boost and tune very gradually for the AFR you desire. Be sure you have a Wideband O2 and not some cheap *** A/F Gauge. Keep AFR around 11.5-11.8 under WOT (Full Boost). Tune for around 12.5-13.0 under spool up @ WOT. Cruising and Light Throttle AFR shoud be around 14.0-15.0. Also remember the SAFCII is good for +/-50% of whatever the ECU is tuned for. So if you get an ECU Tune for 550cc Injectors, you can tune up to 825cc Injectors. I suggest Enthalpy Tune if you decide on a ECU Tune.
