4drmadness »
https://forums.nicoclub.com/4drmadness-u104402.html
Mon Mar 16, 2009 11:15 am
jus stick with the stillen intake box man, not worth spending extra on the jwt popcharger. it wont really give you gains that are worth it, so u shud be good to go man. after the spacer and intake, you still have a long way to go. here is what i would recommend
Get an engine damper, really helps with intial torque- 45 at ebayGrounding wires if your AT- jus get the two wires that attach from the ecu, and transmission, u could make it your selfthrottle body spacer- 100 bucks, 8hp- spacer monkey, coolant bypass mod- freemotordyne aramid gasket- check at motordynes website for this.
This should be good for ur engine
Now time for exhaustI highly recommend the stillen gen 2 exhaust, but i feel the only exhaust that would be better than stillen in terms of gain, but i cant be for certain.Get high flow cats (Fast Intentions, Kinetix, or Crawfors will do)then get headers (DC, Strup, Stillen, crawfords, Nismo) are all great man.
Loose some extra weight lying around in ur car, put in royal purple engine oil, keep up with maintenance. floor ur car
Finally get a tune
