lets see your radiator fan set ups, post some pics!
Sky240PWR
Car: 1991 Nissan 240SX
I need some pics of the flex a lite fans and the Koyo set up with a RB, I have a koyo and 12' fan setup, but it sucks, I do have the twin fans from a altima sitting in my room but I'm thinking of buying the flex a lite dual set up, do you have to do any modifying to get the flex fans to fit with a RB?
integra7
Car: 1995 Nissan 240sx
I dont have any pics of a koyo with the fal fans mounted on it....
But I have dual fal fans for sale. Its model number 240, dual 12" pushers. My friend has used the setup before. The fal fans cover the full face of the koyo radiator and he never had any cooling issues. No modifications needed.
Anyways, if you are interested, I am selling the dual pushers. They are brand new with all the hardware.
Let me know. [email protected]
gawdzilla
Car: none
no mods needed to fit the dual FALs. fits perfect and covers the entire koyo like they belong together. like almost all pushers, you will need to put it in first before the radiator. if you strap the two together first, they won't fit in together.
Modified by gawdzilla at 12:30 AM 7/30/2006
krayton
i dont have mounts that push the rb forward, so i had to cut my rad support.
im running the koyo and flexalites. got an inch at the most clearance to my power steering pump
oh, its an s14 too
edit: heres a pic of mine where you can see the rad and flexalites:
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
I have a FAL 12" puller and Koyo which I was recommanded by my vendor. I'll be installing it soon and when I do I'll post up some pics.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
plz do cause i'm using a 16 pusher and it's working for now but i'd like to have some pullers on my koyo.
nizmo zilvia
If you have a puller do you also need a pusher? Curious.
Sky240PWR
nizmo zilvia wrote:I have a FAL 12" puller and Koyo which I was recommanded by my vendor. I'll be installing it soon and when I do I'll post up some pics.
well I used the Mckinney mounts and I have a RB25 and it looks like I have no room for a puller, I was thinking of a pusher like the one Integra7 is selling. which motor do you have?
integra7 wrote:I dont have any pics of a koyo with the fal fans mounted on it....
I might buy it, let me check on prices first though, no hard feelings.
Ramius83
Car: 1995 240sx SE
I too am using the Koyo radiator with the Flex-a-lite 210 pullers. I have to cut about 1-1.5 inches off the radiator support to fit them in there. I have about 1/8"-1/4" of clearence between the power steering pump and the back of the fans. I am using the McKinney mounts, so that also added to the extra amount of radiator support I had to cut. Also, I cut the lower tabs off the radiator because I was no longer going to be using them and they were getting in the way. I'll try to get some pics for you.
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Ramius83 wrote:I too am using the Koyo radiator with the Flex-a-lite 210 pullers. I have to cut about 1-1.5 inches off the radiator support to fit them in there. I have about 1/8"-1/4" of clearence between the power steering pump and the back of the fans. I am using the McKinney mounts, so that also added to the extra amount of radiator support I had to cut. Also, I cut the lower tabs off the radiator because I was no longer going to be using them and they were getting in the way. I'll try to get some pics for you.
I'm using the exact same setup with the same clearances except I kept the lower rad tabs and slotted the mounting holes to make it a little more secure. Those fans suck and move air like crazy and when they kick on, the temp drops like 5 degrees celsius in only about 20 secs! I also have an A/C fan from an '89-90 mounted as a pusher just incase because it gets balls hot down in Miami!
nizmo zilvia
Sky240PWR wrote:well I used the Mckinney mounts and I have a RB25 and it looks like I have no room for a puller, I was thinking of a pusher like the one Integra7 is selling. which motor do you have?
I got a RB20 and my FAL is 110/120
jrb92se
Car: 1989 Nissan S13 coupe
heres a link to my setup zerothread/188805
