Lets see your maintenance schedules
PoorManQ45
I'm just wondering what your maintenence schedules are like.
Could you give me a description of the things that you do and how often you do them on your schedule. Also, if you can, provide a little information about the previous owner(s). Also, if you would like to, include engine parts/accessories that you have replaced.
Here is my schedule.
I use all synthetic lubes, including oil, transmission fluid, brake fluid, and differential fluid. I change the oil at ~3.5k, or 4 months. Get the engine flushed every year. I change the transmission fluid evey 15k~20k miles, and drop the pan every 50k. It gets completely flushed every year, along with oil flush. The brake fluid gets changed every time I change the pads or rotors 6~12months(usually unnecessary, but I change it anyway.) using sythetic DOT 4. I change the differential fluid every 30k miles(usually doesn't need it, but I do it anyway.) It's always been fed super-premium, with the occasional bottle of octane booster here and there. Fuel filter gets changed every 5k~10k miles. The timing chain guides along with the chain were replaced at 50k miles, by the original owner. I have replaced the radiator(old one cracked) with one that is a little larger than OEM.I have replaced the water pump, alternator, fuel pump, shocks and springs, power-steering pump, and a few bad bushings. And a few other things that I can't think of now.
There were two owners, prior to me. First owners were a 70year old couple, with money. They followed the maintenece schedule very strictly and then some. They are the one's that had the chain and guides replaced. The second owner was a ~40year old couple. The man worked at Nissan. He had a maintenance schedule very similar to mine.
This is a spreadsheet for me, the first owner, and the third owner. Information about the second owner has not yet been entered in.
http://q.spilky.com/irl.xls
I need to go back into my filing box and enter all the mileage data into the spreadsheet, as well as the warranty and dealer work done under the second owner.
psychic_mechanic
Car: the world's ugliest civic
I change my oil every 2.5k and rotate tires every two oil changes.
You've already got a pretty good schedule for the trans and brakes IIRC.
Do you flush TCS fluid and PS fluid as well? When I first got my Q the TCS fluid was pretty dark and I had to reseal my rack & pinion because I didn't flush all the fluids as soon as I got the car.
I'd like to do oxygen sensors soon, I think their accuracy drops off after 60-80k miles.
