gobstopper »
https://forums.nicoclub.com/gobstopper-u24799.html
Thu Jan 20, 2005 3:19 pm
Having been a lurker here for quite a while, I thought I'd share something.
I looked at this thread, and didn't really understand what I was supposed to be seeing on a compressor map. Then I read the turbosaturn.net article, and now it makes some sense. Read that first, if you haven't already.
I read Sport Compact Car most every month, and they rave about Garrett's GT28RS turbo, the 'Disco Potato'. They put it on their project Silvia with the SR20. I wondered how appropriate the 'Disco Potato' would be for a KA24DE, so I did some research the other night. I found a compressor map in Garrett's PDF catalog, so I snagged that, and used the turbosaturn.net article to do some math. Some crappy Photoshop-ing later here are the results.
Some assumptions:
Flow is calculated by the equation
(CID*RPM)/3456 = CFM where CID is cubic inch displacement, RPM is various points in the rev range, and CFM is cubic feet per minute of air flowed.
VE is assumed to be 85%, so the raw numbers are reduced. That number is converted to lbs/min by multiplying it by .069.
Disclaimer: I am no expert. I'm not even an amateur. Consider me a mildly interested geek, and take my conclusions with a grain of salt. I also didn't try to model spool/increasing boost across the rev range, as I would have been inventing a way to do it that I don't know to be accurate or even possible.
Here's the chart:
On this chart, points horizontally are at the same boost level, beginning on the left at 2000 RPM and moving to the right +500 RPM each point until the last point on the right at 7000 RPM. From the bottom up, the boost levels are 5#, 7#, 10#, 12#, 15#, and 18#.
Conclusions: Minimal usefulness for low boost applications. Best for the 12-18 psi boost range, and mighty nice there.
Thanks.
