mp66226 wrote:01 qx4 160k mi. Got a 2" patch of rust right above the left rear wheel where you have to open the door to see. Goes under the plastic moulding there so i am scared to see what else might be under there.
If the rust spot is visible above the wheel well trim/moulding, then you can be 100% sure that the rest of the wheel well that is hidden under the moulding is just as bad, or worse.
These things are prone to rust around the rear wheel wells, especially in a wet environment, or in a snow belt city that uses road salt in the winter.
I live in Canada (Ottawa), where they use road salt to ridiculous levels.
I oil spray/rust proof my truck every year, and there is still rust on the rear wheel wells.
I don't know how you can stop it.
I've been to my local wrecking yard, where there are a number of R50's, and every one of them has rear wheels wells that have totally rusted away.
