cory2081 »
https://forums.nicoclub.com/cory2081-u9472.html
Tue Aug 15, 2006 5:36 pm
Alright, everything is finally installed!! I Dynamatted the rear deck, which took a little time, but, fixed the rattles and made the sub sound alot better. I mounted my amp under the rear deck, just below the sub. The way I did this is with threaded rods, some nuts/washers. It was VERY time consuming, but, it looks AWESOME! You cannot even see the amp when you open the trunk, you actually have to look up at the rear deck to see it It was very hard to hold the amp up and do all the measuring, but, after about 5 hours of laying in the trunk, it finally got mounted. As for the speaker install, I used the factory speaker rings, didn't have to make custom ones from MDF. Had to do a little cutting on them, but, after that the speakers mounted perfect. Removing the head unit was a PITA. Those upper vents are really hard to get out, I thought I was going to break something. Anyway, it was all well worth it. After getting the amp adjusted, the system sounds soooooooooo good. Finally!! I can hear all of the little special effects in the music, and I can feel the snare, guitar, bass, and toms. (sorry, I'm a drummer, those things are a MUST!!) I'll have to post some pics soon.
