C-Kwik wrote:Higher grade bolts won't solve your problem.
Actually that's what I did with the wastegate to mani bolts and it worked. My theory is that softer grade bolts tend to expand more under heat thus separating the nuts from the surface and loosening them. I am however using studs everywhere else, but I'm not sure of their grade.
Quote »Then use mechanical lock nuts(nuts that are compressed at the top slightly) to clamp the turbo to the manifold. [/quote]Can somebody please take a pic of this mechanical lock nuts I keep hearing about? I'm pretty sure I understand what they are but I'm having a bit of trouble communicating my desires to the local hardware store... language barriers :rolleyes
Thanks to everyone who responded to the gasket thing. I'm probably gonna have some metallic ringed gaskets made... had them made for the turbo/downpipe, mid downpipe and cat flanges and they worked great until the bolts came loose. Just wanted to make sure I wasn't using gaskets where I shouldnt.
And node, yep that Copper 888 stuff is great for sealing but I keep burning it off... probably cause of the bolt stuff, probably cause I'm running a bit lean and my temps ain't pretty.
So I'm probably hacing bolt issues, not gasket issues.
Thanks to everyone for the replies.
