So you had, AEM intake, Y pipe, & nismo catback vs eBay catback.Ranga14 wrote:Probably the best comparison video is the one CoupeVQ35CVT and I made here;
http://www.youtube.com/watch?v=_BBtzHJvWmE
That was before I was boosted and him having just the cat back and stock tires.
Hey David, I've been thinking about getting the stillen pulley. Did you feel any difference?Ranga14 wrote:Plus Stillen Pulley and BD Tuner. Almost every bolt on at the time.
It's a Tuner; I'm guessing timing, gear ratio, Air/Fuel and I'm sure other things can be adjust with the tuner.fenderpicks wrote:Im sorry for being a noob but what exactly does a Bully Dog Tuner do for u..?
Fake. They modify your MAF/MAP voltage. So your car thinks it is seeing colder air when it's not. This sometimes will get you a couple horses but it's really bad for your car.iaum09 wrote:Are these fake ECU chips? http://www.gfchips.com/ I saw an ad for them on here so its making me question myself. If I saw these anywhere else I wouldn't even think twice.
Yah I was taking a guess at what it all does; I kind of was scratching my head on the gear ratio, so thanks for the correction.QR25DE wrote:Bully Dog Tuner does not adjust gear ratios...
The tuner will do the following:
- Engine Timing Advance/Retard +/- 2 Degrees.
- 3 Tune Levels (just run premium tune with 91+ octane).
- It has other functions as well, such as a gauge monitoring system (based off of OBD2).
Fully firmware update-able and you can flash right back to stock as it saves a dump of your stock ROM.
To see the benefits you should have at least an intake. If you do not notice much improvement, other things can contribute to it, such as:
- Extra weight in the car (this includes larger heavier rims, stuff in the trunk and passengers).
- Crappy gas.
The whole system is a "closed" system, so you get what is programmed into the tuner and that's pretty much it. It's kind of like a piggy back system but not in the same token.
If you want full control over your tuning you will have to switch to something like UpRev which I run to adjust everything.
Yeah, we were a little, this is a better comparison at highway speeds;infiniti_lineup wrote:Is it just the way the video looks or were you guys traveling down a hill?Ranga14 wrote:Probably the best comparison video is the one CoupeVQ35CVT and I made here;
Yeah, a little bit, it's the one mod that I still have after boosting. It mainly reduces drive train loss due to the stock pulley weighing a ton, but the 2.5 pulley is different than the one for the 3.5. Not real sure on the difference for it.Hey David, I've been thinking about getting the stillen pulley. Did you feel any difference?
Not to be the bearer of bad new but it's certainly more harmful than the BullyDog Tuner.infiniti_lineup wrote:
While I agree with you on it being worthless, it's about as harmful to your car as a Bullydog Tuner.
