hey all,
A couple of months ago i started hearing this strange noise at low revs and periodically at idle. It was especially annoying upon turning off the car. It has gotten louder since then and now is definately noticable at certain rpms.
it sounds like my exhaust is hitting something as it goes with the engine speed and sounds like metal clattering around. I cannot for the life of me figure out where it is coming from though. I know it is definately louder on the exhaust side and towards the back of the engine. I looked under the car and shook everything i saw, but nothing seems to want to clatter like that.
Sooo i took some videos and will share them here:Here is the vid of the engine, it is not as easy to hear it here because my valvetrain is quite noisy.
http://www.youtube.com/watch?v=5esWfqKwa5cAnd here it is when i turn off the engine.. that's the most embarrasing part.
http://www.youtube.com/watch?v=Y_eXf0VE1KM
I can also hear it pretty consistently if I'm coasting in a high gear around 1500+- rpm
I am starting to think it's my bottom end, but i checked my compression and its damn good at 165 158 160 165. I took off my valve cover as well and cams and valve caps look ok.. nothing loose there. the engine has about 23k miles on it, the valve train has been this noisy since day 1
Cheers for input!MarkoWiseco 9:1, Pauter rods, s13 cams
Modified by EstoMax at 9:21 PM 10/28/2009
