UK200SX »
https://forums.nicoclub.com/uk200sx-u106904.html
Mon Sep 29, 2008 9:41 am
Bit of a newb question, sorry, I've never used spacers before and the stickies aren't terribly clear on the subject.
So I am looking at some rims that came off an Altima, 18x7.5 +45 offset. Yeah, I know, FWD offset. If I understand this correctly, this means that the rim will be mounted too far inside the wheel well and could knock up against the brakes/struts/what have you (if it even bolts on properly at all) if it stays at +45 offset. So to correct this, I want to install some 20mm spacers to even things out, and if I understand the offset math correctly this will effectively make my offset behave as if it were +25 and not look quite as goofy?
