nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu Sep 29, 2011 8:47 pm
Fuel pressure gauge, plumb it after the filter before the rail, start the car, check at idle and higher rpm's. Also check it after taking off the vacuum line on the FPR, it should rise. My numbers may be off but I think 34ish psi with vacuum on FPR, and 39psi after taking it off.
Both TPS and IAC have a lot to do with why it idles high at 1100rpms. If the TPS is not adjusted right, not only can it make it die, it will idle high, I think its set at .40. I had pitstop in phx adjust it to .35 and it idled to about 1500rpm, the min I moved it to .40 the idle dropped to over 1000, the higher I set it the lower it got till after I think .5, it just ran odd. After adjusting it run the car and unplug the TPS with the car running to let the comp "learn" the adjustment.
The IAC controls the idle, these should be the first things you check after fuel pressure. How are the vacuum lines? High idle can also be caused by vacuum leaks, so will bouncy idle, so on so forth.
I am not saying to replace them, just test them, testing is easy and free as long as you have a multi-meter. Its never a good idea just throwing parts at it, it will get expensive fast, and may not even fix the issue.
How many miles are on the car? Any major work done to it?
