i love that color combo also...Qxxx4 wrote:thats a gorgeous colour combo, welcome to the nissan truck world! (I love 240's)
Fuelerwhats different in your mod that allows the fogs to stay on when the highbeams are on? Very Interested.fueler wrote: my foglights do everything exactly like you mentioned
it involves modifying the foglight relay... on the relay, there is the power source that clicks it on and off (not the constant power) (sorry i dont know the lingo) well in the stock configuration, that relay on/off power source is run strictly by the low beams... meaning that the fog lights will turn off if you are running the high beams or just parking lights (anything other than low beams).... what you do is cut off the metal tab on that on/off power source and solder in a wire that runs to some other power source, one that is always hot when the car is on and cold when the car is off. (so the fogs turn off when you pull the key out) I ran mine to some neighbor relay that says AC and it works.slickroger wrote:
u should be bannedKoukiS14 wrote:I actually no longer have a Nissan. First time ever.
Seeing as he's in Florida it's probably notNorthern Manny wrote:Hello Jeff, Purchased your Pathy from Wilkes Auto? looks like the building. Got my 2003 from there last Sepetmeber and love it, mine is allso a LE. Mine is in Churchill RegardsManny
I know, but there are others here who drive things like Civics, with no Nissan at all. At least Subaru has shared parts with Nissan since '85.fueler wrote: u should be banned
Same here!bmlawless wrote:I wired them to the A/C relay so they would only come on with the ignition so I wouldn't drain the battery.
Some states require that the lights only function when the low beams are on. Guys who live in those parts of the country keep the stock relays handy so they can pop them back in to pass the annual vehicle inspections.QX4ME wrote:Is there a code about fog light that is not supposed to turn on when headlight is not on? I forgot where I read such thing.
yea east coast states that have "inspection"QX4ME wrote:Is there a code about fog light that is not supposed to turn on when headlight is not on? I forgot where I read such thing.
