sethulrich »
https://forums.nicoclub.com/sethulrich-u5206.html
Mon Feb 23, 2004 6:38 am
My car runs great, pulls hard in the first 15 minutes of driving, but when the engine gets warm it is down on power. Idle is almost always fine, whether the car is hot or cold. Very occaisonally it dips, but that's usually in connection with starting up another accesory, and I assume that is because of increased load on the alternator. Also, it backfires. I'm not sure if that is on the intake side or the exhaust side. Backfiring usually happens if I free-rev the engine, such as on a downshift to match revs. Or if I rev it quickly from idle to 3000-3500 rpm, it may backfire. Also, I do not know if these two problems are connected. So, I have a few specific questions.
1) Is airflow in a catalytic converter affected by temperature? That is, could it flow ok when cold, and then flow poorly when hot?
2) What all sensors affect fuel mixture, and which of these sensors are affected by temperature? The ones I am aware of are O2 sensor, coolant temp sensor, and the MAF. I have already replaced the coolant temp sensor.
3) I don't think it is a dirty MAF, because that would cause it to idle bad and be sluggish regardless of temperature. Is this a correct assumption?
4) Does a bad O2 sensor ALWAYS make the check engine light come on? or is it possible that I have a bad O2 sensor even though the check engine light does not come on? (I know the light works, because it is on when the key is 'on' and the engine not running)
5) Could it possibly be an ignition problem? I'm sure my plugs and plug wires are ok, I have replaced them not too long ago. I have looked at my distributor cap, and it looks fine.
6) Could it be timing?
So, my thoughts are it COULD be the O2 sensor, if it could go bad without tripping the engine light. Or, it could be a bad MAF sensor, which I can check soon. Or it could be something in the ignition...which I wouldn't know how to check. I tried to ask very specific question, in hopes of getting very specific answers, not speculation or nonsense like "My uncle's girlfriend's brother had that same problem and he said..."
Thanks for your help!
