lend me some help - car wunt start and guages dunt work
sci0n
Hey guys, my 240 is giving me some ****. It wont start half the time and half the time it does start, the guages light up but they dont work. Like I can drive wherever I want, but my speedometer, temp, fuel, rpm etc. guages dont work. Any suggestions?
Thanks-sci0n-
AllTurBo
Car: 94 red drop top w/SR
Sounds like an electrical problem to me. Time to bust out the multimeter and start checking the connections.
Could be a bad ground somewhere, The negative battery terminal would be as good a place as any to start.
sci0n
Yea I thought that at first, but I literally just had the battery replaced yesterday, it worked fine before all this, could it be the new battery?
AllTurBo
It could be the battery, but maybe just the way the battery was installed. Check that the connections at the terminals are tight. and if you have a multimeter check the voltage between the terminals.
NISTECH
check your meter fuse and other fuses. if the gauges worked untill you put the battery in I suspect the battery cables were breifly touched to the wrong posts and poped a fuse or 2. as far as the intermitten no start. since it will start sometimes it wouldnt be a fuse as that failure. you may have a bad starter or starte interupt device. manuals trans cars tend to have a problem with either the switch on the clutch pedal or the relay under the hood for the clutch interupt.
SloS13
punch the fuse/relay box near the battery repeatedly. See if that changes anything. Also punch/kick/wiggle it while the motor is runnign and see if anything funky happens
NISTECH
SloS13 wrote:punch the fuse/relay box near the battery repeatedly. See if that changes anything. Also punch/kick/wiggle it while the motor is runnign and see if anything funky happens
awww the good old days. The old school way to fix your car[ and anything broke or dented during your "repair" process]
sci0n
haha i feel russian.
NISTECH
fuse??
