C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed May 26, 2004 10:09 am
Haha....unless that breaker bar is actually designed to "break" the mani. You'll never get it in some of the spots.
And it's not that you can't get to all the bolts. But some are in awkward locations (particularly the lower rear bolts) and the manifold to head nuts from Nissan are Mechanical locknuts. Which means you have to turn it with a wrench most of the way. And not only that, but with such tight clearances, some of the nuts have to be tightened a little at a time. If you tighten one too far, it could make it so you can not get a nut on one of the other studs, or even if you thread them all on first, a runner may run into one of the nuts. It's a PITA, especially the first time. But even after that, access to the nuts is limited and usually you end up using just your fingers to turn the wrench. I'd prefer to pay extra not to have to ever remove my turbo system again. regardless of how good I have gotten at doing it.
