Left Turn Signal Stuck On
Sarcastik
Car: 1995 Infiniti J30 (SOLD)
2008 Infiniti G37s
My 1995 J30 Recently got broken into. A 7 inch motorized screen and dvd player was taken...they also took my ac unit with the hazard light switch. In the process they ripped apart my wiring, but at first everything seemed to work fine until one day my left turn signal light stayed on (not blinking) and it wouldn't go off. I eventually touched one of the wires and it went off.
Well today it came on again and it really wouldnt go off. I got frustrated and started touching more wires and I think I discounted the reciever for alarm keyless entry cause now that doesnt work. So I finally gave up and disconnected the battery so it wouldn't drain. What do I do???
xxcrashxx
Car: 95 Infiniti J30
first off, i would say to take the tape stuff off all the wires.... then use some fresh electrical tape and tape each wire up separately. so im assuming that ur turn signals dont work at all?? best thing to do, is take a multi meter, and play around with the wires, touch the ground end to any metal of the car, then use the positive lead to touch each wire one by one, when u get a reading of 12v, u know thats ur power. then just touch that to each other wire to find out what they all do. i dont believe that the switch is what control the blinking, but from what u said, it could be possiable. good luck on gettin it workin again. ebay works..... :D
