BlackHat »
https://forums.nicoclub.com/blackhat-u38398.html
Thu Mar 30, 2006 8:31 am
Well, there's a couple ways to tell. Depends on how everything is hooked up. If it's an aftermarket setup you might be able to splice in the left speakers on the right channel. That will test the wiring and speakers. Just make sure to disconnect the right ones first.
If everything is nice and neat in connectors you can take the right speaker and try it on the left side. That won't tell you if there's something wrong with the wiring, only if there's something wrong with the left speaker.
No matter which way you go, you need to check the wires going to the left speaker and make sure that there are no breaks or cuts.
If you're on the stock Tape deck head unit.... CHANGE IT FOR THE LOVE OF GOD! Then deal with bad wiring or bad speaker afterwards...
Hope that helped.
