jpnissans13 »
https://forums.nicoclub.com/jpnissans13-u121657.html
Tue Dec 22, 2009 7:45 am
ok so today is checked if the socket has power. it does, both high and low beam.
i fixed the high beam problem by simply running a wire from the passengers side lamp, high beam power source, to drivers side high beam inlet or however you wanna call it. tried the same thing for the low beam, but it did not work. My question is are there two bulbs in the same headlight? If so im thinking that the low beam bulb is out.
