left headlight wont turn on?
xS-13x
Car: s14
so i was leaving my friends house and i noticed my left headlight wasnt coming on. so i went to advance and got me a new bulb. put it in and it still wont come on. all my other lights work. and so do the high beams. What is the problem? a short or something in the line? how hard would it be to replace. and its on 95 s14
Klits562
Car: white s13 coupe
idk about s14's but check the fuse box for fuses there should be 2 i know there is on the s13. If that doesn't work get a multimeter and check to see if your getting pwoer to the bulb if not then trace it back till you get power then you'll know what the problem is.
xS-13x
Car: s14
i checked the fuses and i cant follow the wire far enough back to check it for power. but the high beams still come on? im stumped im no electrician. could a shop find the problem or will they just replace the bulb.
Klits562
maybe the switch on your steering column i know on s13's this can cause problems you can try taking it to a shop but make sure its not a lazy shop
