If you are leaving the parking brake, it needs to be adjusted to keep it off the footrest.Wiggler wrote:Does anyone know how to take this out?? it seems like the footbrake travels into the fixture when engaged.
Thanks... but do you have information useful to the main problem of removal?If you are leaving the parking brake, it needs to be adjusted to keep it off the footrest.
When the hell did I say I wanted to remove the parking brake??? I'M ONLY TALKING ABOUT THE WIDE PLASTIC PIECE ON THE FLOOR, that actually doesn't make contact with the pedal at all if the brake is properly adjusted.maxnix wrote:Removal of the parking brake? Not a good idea! Better to adjust it properly.
Wiggler wrote:When the hell did I say I wanted to remove the parking brake???maxnix wrote:Removal of the parking brake? Not a good idea! Better to adjust it properly.
Initial post was a little vague and confusing.Does anyone know how to take this out?? it seems like the footbrake travels into the fixture when engaged.
