heel-toe : used for downshifting & decelorating the car at the same time. by pressing on the brake with part of one foot, uses the brakes to decelerate, at the same time with the same foot, applying gas to prepare rpm speed matching with rotation of tires before entry.... <-- this style can be modified for drifting by doing a clutchkick style if u wish to power drift into a turn. in the end it's all the same, balancing the wieght/force distribution for proper entry.
Left Foot Braking: sums up to the end of the above, all about wieght transfer. c-kwik gots the 'theory' down pretty good.
think about what would happen if u left foot braked prior to entry while on the gas?
1; spin the back tires & get the rpms up.....
which would be beneficial to get it in the 'powerband'.
would be unbeneficial due to excessive/un-needed wear on the brakes....
From what i've seen, nobody has done 'perstyle' a leftfoot brake entry... it's un-needed... standard style of initiating a drift is brake drifting.... by that i mean. INSANE entry speed, "this style is also known as brake drifting".
coming upon a turn waaay to fast, balanceing your entry speed just right to be able to get ON the brakes causing severe dive/wieght transfer to the front tires.
while transfer/feeling the shift of the car to the front tires, begin initiating the turnin... if still observing understeer you can...:
trail brake to bring the back end out... give the ebrake a pull to bring the back end out... clutchkick to bring the back end out. If the above does happen btw, it means your entry was way to fast for that style for the cars setup... or if u got a heavily modified ride,or past the cars limits... you may want to either make a slower entry to prevent understeer... or try a "finland-flick?" <--can't remember the nickname for it. well.. anyhow, it's also called a feint drift... where u initiate a turn/flick away from the entry direction on the straight... then turn/flick it to the entry/apex of the turn. you may need to adjust throttle position & or apply the brakes to induce the proper wieght transfer to begin the slide.... and to cover the first of the above paragraphs and this one.... it's then control of the throttle and steering if your entry was properly executed...
Hope none of u live up here in the north seattle area.... i drift to and from work.. speakin of which.. i'm off and headin home.. it's 1am...
time to have fun.... yeah i do the solo 2 class stuff at the boeing parking lot up here if any of u from around here...
oh last ramble... the toe-heel technique can be done where ever you go.. it's a good skill to get down.... i've passed multiple high hp cars into a turn... in a turn.. and exiting a turn because the driver doesn't drive there car to the limits... hopefully sometimes this year i plan on getting an LSD setup.... i hear that'd make exits a little quicker ... more controlled....
love reading your guys/girls posts... i just don't post much... lol uhh reading the above.. i'm sure u'r all glad :P
