PoorManQ45 wrote:From the power that each series draws, and the overall power of the circuit, does that mean that you have a total of 15 series circuits, or 7 series circuits?
The overall currents draw I stated is just an estimate. The actual current drew by the circuit is 18mA x 12 = 216mA or might be a little off by 5%. On each circuit board, there're 2 rows of 6 resisters on the sides. Each resistor is in series with 3 LEDs, hence there're 12 series, each series has 3 LEDs and 1 resistor.
PoorManQ45 wrote:When doing the Gauge cluster lights:Will the LEDs be adversely affected by the attenuation knob(dimmer)?
I haven't done the gauge light for my Q yet. However, I had done the gauge for my Sentra about 4-5 years ago. I used 1 blue LED with a resister in series in placement for each regular bulb. The top half of the dimmer does have an affect on dimming my LEDs, but I'm sure it also based on the value of the resistor you pick. I didn't really get to use the dimmer since 1 LEDs in no way is more powerful then a regular bulb.
PoorManQ45 wrote:What are you mounting the circuit to? Are you using a PCB board?
I'm using a 2" x 2.5" predrilled PCB bought at a local electronics part store.
PoorManQ45 wrote:Also, are you using any cluster holders for the LEDs? What I'm refering to is a small plastic piece that can usually hold about 5~20 LEDs. All you do is plug in each individual LED, and then there is a Positive lead on one end, and a Negative lead on the other end.
No, I'm not using that. I don't think I ever seen one before. I'd prefer to use PCB since it offers me the solution for an intergrated circuit. I could solder the electrical components on the same board as the LEDs board. Less one circuit to worry about and save space.[/QUOTE]
PoorManQ45 wrote:Can you post a schematic whenever you get the time?
Definately will. I'm waiting for a friend to come back from out of town so I can borrow his MS Visio to draw the circuit. Otherwise, I might go to school tomorrow and use the computer there.
PoorManQ45 wrote:What are the specifications on the capacitor that I circled in the picture?
They are output capacitors, value of 1uF. The input capacitors (brownish color next to the T-317) are 100pF. Beside the 12 resistors for the LEDS, there's 2 more resistors on the back side of the circuit, to determine the output voltage. And that's all. Very simple.
