I had LED headlight bulbs in my truck's halogen housings and they worked flawlessly. Light pattern was the same but brighter on. sounds like i will be going that route with this rogue but i was checking to see if anyone on here has done it already. I believe someone has already thrown HIDs in the halogen housing which is a no no in my book. The LEDs i have/would used are designed/setup on the headlight bulb for halogen housings.followingnfront wrote:OP.... LED headlight technology has not been around for a a long time. It is difficult to get optcs right to project light properly from an led bulb. Dont take the lazy mans route and throw led bulbs in your halogen headlights. The optics are made for halogen only... You think your output is bad now? Throw some LED bulbs in there and you will have nothing more than another set of parking lights.
Look up a hid projector retrofit or spend the doe on a set of oem LED projector headlights. Only way to utilize those technologies properly
Before/After - Low Beamsfollowingnfront wrote:Got pics of the output on your truck? I dont believe that. Leds are simply not made to the same optics. That bulb may have a base that is made to fit in your halogen based headlight housing... but it does not have the same optics. If it were that easy, everybody would just be using LEDs and it would not be illegal
Halogen reflectors are designed For the position of the filaments in the bulbs and how they shine out. Same goes for hid reflectors and hid bulbs. Neither are meant to be used in a housing that is not meant for it... And the same goes for LED... And i dont know what you meant but halogen housings are NOT meant for bi-xenon....JB'sRogue wrote:Here is a fun fact for those that mmeaow...most halogen housing for a bi-xenon light are designed so any light hitting the top secthaleflectors directs light down and out. Any light hitting the bottom half of the housing projects the light wide and straight for high beams. The manufacturer of the bulbs i would purchase has done alot of R&D to make sure they are safe.
I meant dual filament bulbs but had a brain fart ATM. they are DOT certifiedfollowingnfront wrote:halogen housings are NOT meant for bi-xenon....
I have did some tests of my own and there isnt any glared. I know most if not all PNP HIDs in halogen housing the light will light up the back of signs after you pass them. The LEDs i had didnt do thatfollowingnfront wrote:Those ouput pics are impressive i must say. But the problem associated with using mismatched bulbs is glare. They might be brighter, but they may also have stray light that blinds oncoming drivers... That is the big problem with hids. And it is all because of the different optics
FYI: DOT certified just means that installing them in your car will not damage your vehicle. Many aftermarket Xenon/HID and LED headlight conversions that are DOT certified are not technically street legal...followingnfront wrote:Halogen reflectors are designed For the position of the filaments in the bulbs and how they shine out. Same goes for hid reflectors and hid bulbs. Neither are meant to be used in a housing that is not meant for it... And the same goes for LED... And i dont know what you meant but halogen housings are NOT meant for bi-xenon....JB'sRogue wrote:Here is a fun fact for those that mmeaow...most halogen housing for a bi-xenon light are designed so any light hitting the top secthaleflectors directs light down and out. Any light hitting the bottom half of the housing projects the light wide and straight for high beams. The manufacturer of the bulbs i would purchase has done alot of R&D to make sure they are safe.
It doesnt matter how much "r&d" the company did... It is illegal to use bulbs of different optics in halogen housings.... If this company's bulbs are not dot sae certified to be used as halogen bulb replacements then they arent legit
