Guju Rider »
https://forums.nicoclub.com/guju-rider-u107249.html
Wed Dec 24, 2008 4:49 pm
yea i've done them all except the side markers because i wasnt sure they turned on when the head lights were on but then i found out that the stock bulbs were just blown out..but yea..i have white LED's all around..just to let you know..dont change the bulb that is in the head light housing to LED because it will start to flicker after some time..i did it and it worked great and looked great with my 8000k HID's...but then something happened to the bulb and it kept flickering and i gotta warning for having lights that imitate a cop...i got all might lights off of ebay..there are a few hard ones to get out..the map lights in the front of the car..be careful not to break anything..be gentle when taking out those lights...in the back of the car..you going to have to take the whole thing out to get to the screw holding in the plastic piece...also under the door on the front driver and passanger i changed out....if there's anything else..ill try to answer the best i can..good luck with the switch out..you're gonna like how it looks...by the way..what color are you getting?
