LED work
All things Altima Coupe.
SanoSuKe
So I just got some LEDs installed. Only reason I wanted to share this is the day time running lights or I dunno what do you call them. I had that orange bulb removed and replaced with white LEDs, it looks SOO much cleaner I recommend it to all 2010+ models. I pretty much deleted the day time running lights but they still work as left/right signals.
crappy cellphone vid but you get the idea: http://www.youtube.com/watch?v=VSpcvpzBCEo
aphu
Car: 2010 Nissan Altima Coupe
Where did you get them from?
SanoSuKe
aphu wrote:Where did you get them from?
a friend of mine does LED work. He installed them for me when I met him at Eurofest car show. But I can find out for you what exactly are they/where to buy them.
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
I'm ordering a switchback bulb for that soon so it'll run white and blink amber
aphu
Alright cool
MetallicSlate
Car: 2008 Altima Coupe 3.5 SE
Is your friend going to hook you up with some resistors to stop that hyper flashing?
skiski329
Car: Nissan Altima Coupe 3.5
looks really good! i've wanted to do that for such a long time. just looking for a switchback.
AlexN09 wrote:I'm ordering a switchback bulb for that soon so it'll run white and blink amber
WHERE?!?!?!?! i've been searching everywhere to find a switchback! I e-mailed v-led's and they said that they don't make switchback 194's
YoungCoupe
Car: 2011 Altima Coupe 2.5s Metallic slate
skiski329 wrote: WHERE?!?!?!?! i've been searching everywhere to find a switchback! I e-mailed v-led's and they said that they don't make switchback 194's
Pretty sure the turn signal bulbs arent 194's...but I could be wrong.
SanoSuKe
MetallicSlate wrote:Is your friend going to hook you up with some resistors to stop that hyper flashing?
hmm I haven't thought about that! I might get it, the hyper flashing doesn't bother me.
MetallicSlate
No turns aren't 194. 194 is usually an interior light like the courtesy or dome. Turns on the 08 are 3457NAK in the users manual and 3157 fits nicely.
Check out www.v-leds.com for all your led needs. :)
Millhouse14
Car: 2012 Altima coupe
I have a 2012 coupe and I tried putting in some chrome turn signals. I used size 3157 and there was NO way they were fitting! I checked the owners manual and it did indeed say it was 3157 but it is wrong. I know this because i changed my stock hids and the manual said my bulb size was d2r. When I poped it out it was a d2s. Anyone have any idea what size the turn signals could be?
skiski329
i have a 2012, but i'm assuming they are the same for the 2011. from sylvania the turn signals are 2827. and the 2825 are the yellow sidemarker bar. I searched on google to find the equivalent led bulb and found they were 194's. i guess i did a bad search. I'll have to grab my owners manual and check to see what that are.
http://www.sylvania.com/en-us/applicati ... 23&make=65
skiski329
****Bump**** has anyone found the turn signal led for the 2012????
skiski329
Well after no reply and a 10% off coupon set to me by VLED's i decided to take the plunge and the the switchbacks 3157's i hope they are standard cuz i did not choose CK.
sidenote; also got led's for the L plate, door step lights, and map lights. should look great!!!
