djoxide »
https://forums.nicoclub.com/djoxide-u98387.html
Mon May 18, 2009 5:08 pm
so first off you'll need some window switches from a 02-06 altima (coudl also be maxima to i just stubbled across these one day at the junker)you can see ours on the left (non transparent switch and the right transparent switchtake yer switch outunscrew the 3 aroudn the whote cappop the top off the white cap, firstly take the window lock button off carefuly otherwise it won't release from the bottom portion of the unitpop your switches offnow get your altima switch out, and gently shave the plastic nubs down on the back and middle pieces, this is so you can still go up and down without the switch sticking, trial and error just don't shave off alot at firstdrill holes in the base front of each switch areafit for ledswire your leds up, i wried all 3 up in series to the master auto button light that is already attached to the boardso now the lights will all come on when you turn the lights on to your carfor the pass and back seat lights i wired them to a power source (cig lighter) so they are always on but you could do that and put a switch somewhere so you can turn them on off on your ownpass & back switchnow my leds were freakin' bright so i used 2 1.5k ohm resistors on the wires (this is what i had in the house), depends what you want to for brightness)put it all back together
i also just replaced all the bulbs in the hvac with leds
