LED Upgrade Project + Dome Light Conversion
Ilya
Has anyone had issues with the turn signals and LED's? Do they blink fast (need a voltage regulator)?
mexillis
Car: M45s
i havent done it yet but have heard you get the hyper blink. I'm not sure if anyone has had success with a v. regulated bulb or not
zerg711
Anyone with a 08+ successfully change their front sidemarker bulbs to LED? I opened mine up and it is a single piece that cannot be twisted off.... The only way to change the bulb is to put it in the oven and bake it...
zerg711
SimonSaysM35 wrote:
SimonSaysM35 wrote:OK guys, i need your help. Im about to place my order and need to make sure I chose the correct products. Frankly, I have no idea what to expect. Your help is greatly appreciated!! Any info about if these lights will work correctly or info about what to expect to happen would be great!
1. Parking light (front) lil bulb: http://www.v-leds.com/Interior-LED/Gaug ... 38587.html
2. Side Marker turn signal working light (orange/front panels): http://www.v-leds.com/Exterior-LED/Corn ... 94231.html
3. Turn signal working light (orange/front): http://www.v-leds.com/Exterior-LED/Park ... 10365.html
4. Turn signal working light (orange/rear): http://www.v-leds.com/Exterior-LED/Park ... 10365.html
5. Reverse/Back-up light (rear): http://www.v-leds.com/Exterior-LED/Park ... 82918.html
6. License plate light (rear): http://www.v-leds.com/Exterior-LED/Corn ... 78377.html
Im worried that there might be the "fast blinking" and so forth, especially the side marker turn signal light on the front panels. Thanks in advance!!
Anyone mind helping me out with #'s 2, 3 & 4, please? Thanks in advance!
You should probably check your sidemarker housing assembly. Unlike the FSM, my assembly is one piece and it cannot be open to change the bulb.
SimonSaysM35
Car: 2008 M35-S
zerg711 wrote:Anyone with a 08+ successfully change their front sidemarker bulbs to LED? I opened mine up and it is a single piece that cannot be twisted off.... The only way to change the bulb is to put it in the oven and bake it...
thats crazy...how did you pop yours out?...
06M4.5
Car: 2006 M45
I did all the leds in my car. 2006 M45
and I have the hyper blink only when turning left or right.
I don't have it when the hazard lights are on.
I like it, it makes it look sportier.
Ilya
Can someone with an 06 or 07 please confirm the sizes of these bulbs?
Running light (near high-beam) - 662
Map light - 60
Reading light - 65
I want to change those out (as well as all the other interior/trunk ones which are 168/158/194) but I can't find those sizes on V-Leds or any other site. Is there an alternate number for those 3?
Thanks!
Ilya
Nobody?
bbs350z
Car: 350z built tt
350z st track whore
m35x daily
evo 8- 30r sold
ill be doing this asap. anybody have discount codes??
06M4.5
Car: 2006 M45
2006 M45
parking light near hi-beam. I used 194
the 2 front map lights. BA9 but I used panel smd
the 2 rear map lights, 1 on top of each rear door. I used 31mm festnoon 6 smd led.
lights on each door 194
lights under steering wheel & glove box 194 with no covers.
side marker on fender 194 (no more yellow)
Ilya
06M4.5 wrote:2006 M45
Thanks. I had the others (I went to every bulb and unplugged it and read the number) but couldn't find the ones above. I figured there were alternates.
Mind providing me with links to the BA9 and 31mm festoon lights you got?
jesustorres85
Car: 2003 SILVER M45 20 INCH FX45 RIMS FULL LED BULB SWAP
06M4.5 wrote:I did all the leds in my car. 2006 M45
http://www.v-leds.com/BlinkerWarning-Fi ... 8-1-2.html
06M4.5
Car: 2006 M45
i used a board like this for each front map light:
http://cgi.ebay.com/ebaymotors/Flux-Fes ... ccessories
and this for the rear:
http://cgi.ebay.com/ebaymotors/2-31mm-1 ... ccessories
Ilya
06M4.5 wrote:i used a board like this for each front map light:
Thanks man!
06M4.5
Car: 2006 M45
I did the same. I took every bulb out and ordered what I needed. interior, exterior & trunk.
the only bulbs I haven't done yet is the Hi-beams.
Ilya
I recommend non-HID bulbs in the high-beam. It takes too long for them to get cooking to be useful.
I'm running Sylvania Xtravisions (supposedly really good in inclement weather). That was the best halogen bulb in the Maxima world, so I can't imagine it's much different for other cars.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
Any issues with your leds flickering because of the auto dimming? I asked this question before but I don't remember if anyone answered.
riggz
Car: 2007 M45S
IlyaKol wrote:I recommend non-HID bulbs in the high-beam. It takes too long for them to get cooking to be useful.
I agree with this. A mix of both HID and halogen will yield the best results IMO. I went with the Slyvania Silverstar Ultras. They work great and look good too.
DoN_BLaZe34
2006 FX45 - Traded
any chance one of you two can get pics up of those high beams?
Ilya
Pics of the output? I could do that, sure.
06M4.5
Car: 2006 M45
none of my leds have a flickering problem because of the auto dimming.
they work just fine.
JasonR
Car: 06 M45 Sport
How much in total would you say you have to spend to replace all the interior light to LED?
DoN_BLaZe34
2006 FX45 - Traded
Ilyakol, yeah pictures of the output, thanks
Freddie, thanks for the follow up
Ilya
I'll try to get some tomorrow.
MOWellsinVA
Car: 2007 Infiniti M45 Sport (Obsidian Black w/ Graphite interior)
Thanks man!
I went ahead and ordered these myself, and I'm looking forward to seeing how well they will perform.
Ilya
DoN_BLaZe34 wrote:Ilyakol, yeah pictures of the output, thanks
Might be a little brighter due to the camera/rain but here is the output.
9005 Sylvania XtraVision bulbs in the highbeam:
riggz
Car: 2007 M45S
What is that black mountain to the left of the driveway?
Ilya
Parents needed some dirt for some gardening in the spring lol. We have an orchard and grow pretty much everything from strawberry's, tomatoes, potatoes, corn, apples, pears, blueberry's, grapes, etc.
riggz
Car: 2007 M45S
Wow did they order a dump truck load?! lol
Ilya
Yeah. My cousin has a dump truck, so he gets it for us.
We have 2 acres of land...and they have planted a lot of stuff all around lol.
