LED turn signals....6 ohm 50w resistor sound good?
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
Hey guys, how can i simulate the flasher signal on a power supply to test what resistance is right....I have a digital logic board and 555 adjustable clock timer...anybody with experience on how the circuit works? Id like to test resistances before i solder them into the circuit of my qx4. I wana do front and rear turn signals, and obviously know the no load effect and need for a resistance. I read on a site that a 6 ohm 50 watt resistor works.
also, any tips on how i can keep this addition waterproof? radioshack buffs help me out!
Axelpkt
Car: 2002 Nissan Pathfinder 5spd
http://www.superbrightleds.com....htmlscroll down to electronic led flashers, you just have to replace the flasher in the fuse area, no soldering involved.
Qxxx4
2012 Ford Mustang
very nice! thanks
RR425
Car: 2001 Infiniti QX4
Is it this thing?:
https://www.amazon.com/dp/B008C9YJ6C/re ... NVRSERBHJK
And you just replace the stock flasher relay with this and that's it?
It's one of the three relays that are under the dash next to fuses?:
http://i.ebayimg.com/images/g/--YAAOSwg ... s-l300.jpg
Got some LED rear turn signals and they hyper flash.
