Q451990 wrote:It would definately freak out. I tried some plug-n-play LEDs from http://www.tmiled.com and although they looked great the warning came on.
The sensor in the trunk senses the current draw from the bulbs, and depending on what it senses - either sends ground or nothing to the ECU. Ground the wire to the ECU and you're done...
Heath
Y THANK YOU VERY MUCH....I FOUND THEM IN JAPAN AFTER ABOUT 3 MONTHS OF LOOKING......ALL I HAVE S THE PICTURE THOUGHAZhitman wrote:Jebs, those are SO hot.
You need to apply an additional current load on the line to match the total current draw.chinaonnitrous wrote:Exactly what I was thinking, theres no way I could wire up enough LEDS to emulate the current draw of thoes bulbs in there now.
Any idea which wire it is? (per FSM?), otherwise I'll poke around with the volt meter.
Having just a resistor in series will not generate the current flow you need... Rather it will do quite the opposite and make the problem worse. We're trying to generate conductance...not resistance. Nothing excess about it since it's the lack of current flow that sets off the warning in the first place. I'm sure someone can come up with a better load than a light bulb but it's all I can think of right now. My whole point behind this is to not disable the warning lamp which might save a few tickets $$$. Remember, there is also a flasher relay to deal with.Q451990 wrote:Rather than using bulbs, why not put a resistor in series? I suspect it would generate quite a bit of heat. The only reason I would do this is if the warning would still work if the LEDs died... otherwise it's just excess voltage draw.
Regarding the LED turn signals... I'm running them on the front. They will cause the flasher to "fast blink" as if a bulb is out - but I replaced it with a solid state one from the same web site.
Heath
Do you have pics you can share with us?elwesso wrote:if you wire it right, it wont effect it..... I hooked my LED's right up and it didnt do anything...
You're absolutely right... a resistor in series would drop the voltage down. Sorry... I think I meant to say resistor to ground. Wouldn't that creatate a load that, at the right resistance, could simulate a bulb? My understanding of light bulbs is that they're basically resistors that convert electrons into light and heat. A resistor does the same thing, but without the light part...DrewQ45 wrote:
Got an update?heywier427 wrote:so has anybody figured this out yet. or have we given up. how do you think a set of clear tails would look with rows of the larger (10mm) leds would look. ive got a set of broked tails so im gonna try. remove orange red lens. keep the plastic light defuser in there and use that to hold the leds. just drill the holes and glue them in place. but before that have the insides chromed, fifty bucks. then cut out a piece of plexi and heat it up till it contours the housing and glue it down. maybe slant the led rows like the g35! my cars pearl so it should contrast. fifty bucks for taillight chroming. spending more time with my Q, priceless...
