LED switch with other dash switches? (ECO/SPORT/AWD/ETC)
plainsman
Car: 2015 Nissan Rogue
Where could one buy one of the switches to put in the location of one of the blanks (assuming one doesn't have all the options filled up)? I'm considering aftermarket under dash/footwell lighting. There seems to be plenty of inexpensive options out there, but I'm not thinking that I want to remove all the trim required to get a switch to the center console storage compartment (which is where the factory one goes). Seems like a logical place for the switch would be right beside the forward collision button. Maybe I'm missing something, but this just looks like the obvious place to put the switch, right beside the last used slot. Figure if I can find a blank, I'll label it LED, and then wire it up.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
I don't think you will find a switch the same size and shape as the others.
Maybe consider drilling a hole in one of the empty blank covers and put in a switch like this?
https://www.ebay.com/itm/2x-Small-Black ... 0033.m2042
macgiver
Can you utilize , gotten from the J-yard , one of those switches that fit in there -Cover wording/symbols using "spray paint- for plastics " (black ? then put like- Brother label ,w/white background) Label yours apropriately.
:cool: That may be the neatest - closest to stock look. G 2/27/2018
plainsman
04pathse wrote:
Tue Feb 27, 2018 12:00 am
Wow, that's a pretty simple and straight forward solution. Hadn't thought about drilling into the blank. Thanks for the suggestion.
plainsman
macgiver wrote:
Tue Feb 27, 2018 2:18 am
I had thought about the salvage yard, just don't know of many close by. But that is an option as well.
04pathse
I wonder if this would work for you...
https://www.ebay.com/itm/12V-3A-Push-sw ... B4&vxp=mtr
Return to “Rogue Forum”
