xtwoonamatchx »
https://forums.nicoclub.com/xtwoonamatchx-u73446.html
Sat Jun 14, 2008 6:06 pm
if you wire to the dimmer, make sure you ground ( - ) to the MIDDLE black wire... and all you need to do to pop off the side panel is to take off the fuse box cover, and reach your hand in and push the panel from the inside, and it will come off... then unplug the harness to the dimmer, push in the power ( + ) [ usually a red wire or black with a white stripe] wires into the purple and the grounds into the middle black, make sure you push them into the connector real good, and wrap everything with electrical tape to make sure they dont come loose. thats the easiest way... and i highly doubt nissan will put them in for you.
