I have order 4 red LED lights for the brake and turn signals, and 2 amber lights for the front signals. They are VLED's brand lights with VLED resistors. I installed the lights and resistors today, and of course something messed up. My rear parking lights will not illuminate at all, but when I press the brake or put the turn signal on they will light up. I only installed resistors for the lights being used for the turn signal. Does anyone have any clue what this problem could be? I thought it may be the turn signal relay, but came to find 07+ Sentra's don't have the standard type relay. My two front lights are fine, so I am just totally lost now on what could be wrong.
*Also, the resistors are 6 Ohm 50 W, what is the real difference between the 3 Ohm and 6 Ohm? For my application, replacing all the turn signals and parking lights with LED's, which one is best to use? Do you think it may have something to due with my problem?
