LED running lights
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
Darkhorse
Car: 2011 370Z
Hello all,
I'm in the process of installing Alpena MAX LED lights on the headlights of my 2011 370Z. Should be done by tonight. I'll post pictures later.
I'm jealous of the new Audi's running around with those cool Led's.
Link to photos...
http://sdrv.ms/MeewNG
Darkhorse
Car: 2011 370Z
This project is turning to $hit... This morning the led's and parking lights stopped working. It blew the 10amp fuse for the circuit.
More later.
Darkhorse
Car: 2011 370Z
OK,LEDS installed and working. I had to install a resistor in the feed to the lights. I used a resistor from the old points and condenser ignition days.
Lowered the voltage 2volts. Lights are at good intensity and 10amp fuse in the parking light circuit does not blow.
A total of 37 plastic clips and 35 10mm hex head bolts removed to remove both headlights... :rolleyes:
Return to “350z / 370z Technical”
