Pwnin O’Brien wrote:
Bump
Are the LED's really bright at night when turned all the way up(distracting at all)? Did you sand them down to increase the output angle?
It would be awesome if the LEDs could be wired up so that they are fully lit when the dome light is on (door open, etc.) and then dim down to the potentiometers level when the dome lights turn off.
When they're lit up at full power they're the perfect brightness to accent the footwells and provide enough illumination to see everything. When I wired these up I wasn't aware of the sanding to diffuse idea so no I didn't do that for these. I imagine that it will give is a softer glow and will probably do it tonight. I'll take some before and after pics with the same exposure.
As far as using dual 12v inputs it could happen if there was a 12v priority switch available. I've work with priority switches for video signals but have never seen one that prioritizes power. I'm sure there's something out there.
Billy
