LED "NISSAN" emblem write-up
All things Altima Coupe.
Coupeguy23
Car: 2006 G35 coupe sport
jagr200 wrote:Ya I just finished up this mod along with the door handles that light up. Very easy and very nice looking.
could you post up some pic
bina12834
Car: 06 G35 coupe
jagr200 wrote:Very easy and very nice looking.
i wouldnt call 8 hours of work "easy"
jagr200
Car: 2006 Nissan Altima 2.5S
I am on a roadtrip right now but I get home late tomorrow evening. I will put up pics when I get home.
jagr200
It wasn't all that bad. I was in no rush and just enjoyed myself. Listened to music, drank some brews and just had a good time. I make my installs completely perfect. I won't settle for anything less. I was also planning out my headrest monitors at the same time. Those will start going in on Thursday hopefully. Had I got down to business I could of done it in about 2 hours easy.
Curtieson
Car: 2008 Nissan Altima Coupe 2.5S
This does look really slick! I wish I had a dremmel...I would be up for making see threw emblems...once you got the materials I think you could do that part in an hour or two.
As for the tissue someone commented on...the tissue is just there is push the tint up tight against the logo. You could use toilet paper...anything to make sure you have a good consistant touch between the tint and the logo.
Also you don't have to fill it up to the top, you just need to put enough in to create a barrier between the elements and the tint. I would say 1-2 MMs of glue stuff.
xman1967
Car: 2008 nissan altima
sik anyone wants to build me one and of course i will pay for it i love it, its awesome
bina12834 wrote:found this on the "other" forum....pretty sweet....all credit goes to "TITEALTY" from the "other" forum for doing this and the write-up.....
"after i installed my LED door handles everyone asked me for a write up. I didnt have one so made sure to do one on my this project. "my LED front grille emblem". IM me if you have any questions .. hope you like.OK... lets get started.. things you will need...-Dremel rotary tool or equivalent tool-different sized routing bits-epoxy(preferably clear) with mixing tube for easy application (see pic)-masking tape-led strips( $10 off ebay)-your emblem of course-strip of automotive tint 20% 1"x8"-reflective tape(or chrome vinyl)-white vinylstep 1...drill out the inside of the letters using a rotary tool.. here is a video of me drilling out the "I" in NISSAN.. dont lose the little triangle piece from the letter "A". it'll look weird if you do
http://www.youtube.com/watch?v...edded
step 2...place strip of tint behind the letters on the inside of the emblem.. this step is to give the letters a black stock look while making it transparent. step 3...tape some tissue paper behind the tint to keep it in place...step 4...lay it it on a flat surface and get your epoxy ready (this picture has the epoxy with the recommended application tube)step 5...now. this step requires a steady hand.. after replacing the tiny triangle for the letter "A" ,attach the mixing tube to the epoxy container and gently squeeze the epoxy into the letters you drilled out..i recommend discarding the few drops of the epoxy for it may contain bubbles from mixing.(MAKE SURE NOT TO OVERFILL).. let it cure and you have a transparent nissan emblem..sorry for the blurry pix guys.. my camera sucksstep 6...line the inside of the emblem with reflective tape to keep as much of the light inside the emblem as much as possible.. i used chrome vinyl.. make sure not to cover the letters.step 7...lights!... here are a few pix of the LED strips i bought off ebay for $10 for four.. run the lights through the holes where the clips on either side used to go.. now place white vinyl on the grill itself as shown.. this reflects all the light and gives you that crisp solid white glow.. any white material can be used if vinyl isnt available..now add all four lights on the topside of the lettering.. through trial and error i found that mounting the lights above the letters looks the best..i tried mounting them directly behind and mounting them below the letters. but with both methods the LEDs could be seen.. mounting them above seems to be the best way to hide them. step 8...make your wires look all pretty.. i added connectors to the ends just incase i need to remove my grille again i could disconnect the wires instead of clipping them. note since i removed the mounting clips on either side of the emblem i zip tied it back into place..it works pretty good. see pichere are the wires i ran from the dome lights to my LED door handles and now to my lighted emblemnow reassemble and YOU'RE SET!!!!!! ENJOY here is a short video of the finishing product .. i know its really dark but i will update with a better video soon.. tune in next week for a custom amp rack write up.lol
also here is vid of my door handles (for those who havent seen)..http://www.youtube.com/watch?v...edded"
Modified by bina12834 at 9:55 AM 5/1/2009
Modified by bina12834 at 5:21 PM 5/1/2009
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
Bumping really old threads and then quoting a wall of pictures and text is not cool. This looks pretty easy hence the DIY, why don't you try your own hand at it.
KilLer_KenZz
Car: '09 A/C 2.5S
That's pretty sick. I might look into doing that one day.
Kanard
Car: 2008 Nissan Altima Coupe!
I really,really, really like that.. i wanna try that out, but short on time, id also want to cop another emblem.. hehe..
Joeskey
Car: 2.5 2009 Altima Coupe
Im trying this mod today! Hopefully it goes well, and also does anyone know if i can remove the emblem fairly easy? as in without having to take my front bumper off>?>?>?>?>?>?>
coupecrazy1232
Car: 2008 Nissan 350Z Nismo 1430
Joeskey wrote:Im trying this mod today! Hopefully it goes well, and also does anyone know if i can remove the emblem fairly easy? as in without having to take my front bumper off>?>?>?>?>?>?>
yes you can...but u have to have long skinny arms...like myself u just have to reach down in the middle with the hood open where the lock mechanism is and there are two clips on the sides that u push towards the middle and it will come right off!! i did this and get ALOT of compliments on it!!!
Vital
Car: 2008 Super Black Altima
All u gatta do is open the hood.Taking the grill off will def make it easier but u can manage without.
It's 3 days after u said "I'M TRYING THIS MOD TODAY" Did u do it??
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
anyone here do it yet?
coupecrazy1232
LongBeachCoupe wrote:anyone here do it yet?
i did it about 3 weeks ago and it looks pretty good...not perfect by any means but it was cheap as hell to do so i was happy with it! the hardest part is finding a place to mount the LED's without them being seen
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
ChinAltima08
Car: 2008 Nissan Altima 2.5 S+
Blackmobile wrote:
Any one write up or has a link to the door handle mod?
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
i doubt i would do this mod, specially since i'm going to get the Stillen Fascia
Desire1314
Car: Altima Coupe 3.5SE 6MT
Seems like a bit too much work for something so little. Very creative still, I have to admit.
Joeskey
its been weeks and im still trying to do this mod lol. im having a hard time getting the epoxy in the letters its not that i dont have a steady hand but the exposy i need it to be more liquidy because its comming out real thick =[
2.5s mila
Car: 2008 Altima Sedan 2.5s Super Black
instead of using those strips, can we use these leds? http://www.oznium.com/prewired-surface-mount-led
maxentropy
Car: '08 Altima Coupe 3.5SE
Love the door handle LED project!
saywat
how are people tapping into the dome light?
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Resurrected!
I CANNOT get this done WTF! I cant get the dremmeling done cleanly, all the bits I have are too big and I couldnt find anything smaller in the store.
Conceding...
andyhenault
Car: 2012 Altima Coupe 3.5SR-Borla axel-back, full LED lighting
2010 Altima Coupe 3.5SR-Wrecked
Joeskey wrote:its been weeks and im still trying to do this mod lol. im having a hard time getting the epoxy in the letters its not that i dont have a steady hand but the exposy i need it to be more liquidy because its comming out real thick =[
If you mix your own epoxy instead of using the type that portions it out for you, you can use slightly less hardener and it will be less viscous. Alternatively you could use a longer set time, such as 20 minutes compared to 5. They also tend to be less viscous.
KillahKev
Car: 2010 Altima Coupe 2.5s
How much would you charge to this ? And labor of cost with shipping pm me !!! I want this but I don't wanna f up a emblem lol
eiger1982
Car: 2011 nissan frontier
Hi there, your mod for the nissan emblem is a grwat idea and your steps to doing so are very detailed which is great. Im wondering if you or anyone else could give me a step by step in how to wire it up so when i turn my headlights on, the emblem lights up? Thank you.
