LED Newbie Help!
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
Out of the links I got from all the threads I read on here for LED's, can someone tell me which 194 LED's are the best to get for the Tags, Dome, and Doors without any fitment issues?
http://www.v-leds.com/Shop/Con...num/2
http://www.v-leds.com/Shop/Con...32481
mikegtr06
Car: 1995 180sx
personally i have
in the map lights doors and tags.
and in the dome light i have these
and that fits but i want to upgrade to
if it will fit.
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
I got a few of these white VLED leds for sale. I have the 11 smt led and 5 smt led types. I bought these from VLed.com. I'll take some pictures of them if you are interested.
Alien_Tracker
Car: 08 Altima Coupe 3.5SE (Dark Slate)
Do the 11 SMTs fit in the doors and maps with no problems?
kuhan
Alien_Tracker wrote:Do the 11 SMTs fit in the doors and maps with no problems?
fits doors with no problems, but A/C map light uses different bulb size. I believe DE3175(?)..
phobs
The two map lights use 194 while the dome light in the back uses DE3175/3022
kuhan
phobs wrote:The two map lights use 194 while the dome light in the back uses DE3175/3022
thanks for the info...then yes, 11 smt leds fit perfectly in the map lights.
deasonz
So on the bulb fitment post it says the A/C map lights are a 578 so is it a 578 or a 194?? I'm lost.. I want to upgrade my Map lights and dome light. the dome is the DE3175 I believe. But I'm still confused on the Map lights.
phobs
Yeah, there's many cross reference numbers for these bulbs. Here's a helpful guide. 578 is a 194 type fitment even though it's not listed there, trust us :D.
http://www.v-leds.com/Shop/Con...Guide
deasonz
phobs wrote:Yeah, there's many cross reference numbers for these bulbs. Here's a helpful guide. 578 is a 194 type fitment even though it's not listed there, trust us :D.
Thanks.. Looking at that guide I see a 558 but not the 578.. and when I look at the pic of a 578 it looks different than the 194. I trust you guys I just dont want to spend 10 bucks on bulbs I cant use
phobs
Most 3 digit bulb numbers are a 194 fitment, but the most safe way is to actually open and check your car for yourself is which I did before buying any bulbs basing on the manual or elsewhere. If you buy from v-leds, type in CLUBLEX in the coupon area for 10% off during checkout.
deasonz
Awesome! Thanks for your help.. I work at a Mazda dealership so I called my local A/M supplier and had him check to look at what it looked like.. the 578 is a fuse style light.. Thanks for the Discount code.!
Alien_Tracker
I just put these in the doors and map lights.
and I put this in the dome light.
They look nice.
deasonz
Alien_Tracker wrote:I just put these in the doors and map lights.
They look nice.
Thank you all for your help! got mine ordered today!!
Alien_Tracker
problem. I had cheap green ones from EBay in before. These are much nicer and the blue looks better.
Coupeguy23
Car: 2006 G35 coupe sport
bump i need help findin the rear lights
zilla19
Are you talking about the dome light? If so, there's the link above.
Coupeguy23
no the license plate and the other rear lights
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
License plate lights are 914's, reverse lights too
2.5s mila
Car: 2008 Altima Sedan 2.5s Super Black
i used the coupon code: bt2580 it was good for 15% on v-leds.com
2.5s mila
Blackmobile wrote:License plate lights are 914's, reverse lights too
914's or 194's?
