LED Mirror
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Mephisto75
Car: Volvo V40, Infiniti EX35
Some stupid as..... has smashed my right side mirror that much that I need to replace it.
I was thinking about replacing it with an aftermarket instead of the oems like this:
fx LED Mirror
There are a lot aftermaket ones for the fx but I couldn't find one for the ex. There are some on the market that seems to fit both, at least they are advertised like this.
Can anyone confirm that both models INFINITI FX /EX use the same side mirror
Tasman
Car: 2011 EX35 - All Options
I highly doubt the mirrors would be interchangeable between the EX and the FX. Besides, the mirrors in that link are for the 03-07 FX and I know that would not be used on the newer EX. Best bet to confirm is call the dealer parts department.
zarar
Car: 2010 Infiniti EX35 Journey AWD
On a side note, be careful at the listing when you purchase them as well. The ones you listed doesn't seem to be an entire assembly, but merely a cover. Not too sure about the fitment but you could measure them and purchase an assembly (left and right, assuming you would want both sides to look the same), but I think if you found one that fit, it would cost just as much as a OEM replacement (purchase from a reseller, obviously dealer will be pricey). If you are attempting to go with the covers, by the design alone you can clearly see that the shape of the FX mirror and EX are different, if you were to replace the whole mirror itself, it could be a do-able custom retrofit. I've seen it done on Maximas, so I don't see why the EX would be any different.
Update: Did a little searching of my own and here is what I have come up with (All I found it Left Side Mirrors). Only question is, which side are you trying to replace? *Also found LED Cover if you are interested in a Cover for a cheaper repair, listed as "Nissan EX35".
EX35 LED Cover: http://cgi.ebay.com/ebaymotors/NISSAN-E ... 2888wt_941
Left Hand w/ Camera: http://cgi.ebay.com/ebaymotors/2010-11- ... 500wt_1182
Left Hand w/Camera: http://cgi.ebay.com/ebaymotors/09-10-11 ... 1068wt_941
Left Hand w/Camera: http://cgi.ebay.com/ebaymotors/INFINITI ... 182wt_1167
Left Hand w/o Camera: http://cgi.ebay.com/ebaymotors/2009-Inf ... _585wt_941
Left Hand w/o Camera: http://cgi.ebay.com/ebaymotors/Infiniti ... 500wt_1182
Mephisto75
thanks for your help!
fortunately the mirror housing itself is ok, just the cover has dents and a big crack.
So the replacement cover you've found on ebay will be the one
inka1
Car: 2008 EX35 Journey w/Premium & Tech packages
Please post if you order and install those led mirror covers. I am looking to do the same thing or similar to make my turning intentions more obvious. I can't believe Infiniti doesn't offer as standard.
Avalanche325
Car: 2008 EX35
1965 427 SC Cobra (Factory Five Racing)
If you do that, you are also going to have to do some wiring to get it to work. It could be a nice mod.
TonyN
Car: 2010 EX35 "The Baby Wagon"
2010 Camry SE "The Beater"
1994 Supra Turbo "The Weekend Warrior"
so did anyone ever do this?
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
This is a very neat idea.
I wonder if the overlay interferes with models that have the camera on the underside?
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
