LED issue
edogg27
Car: 2003 Nissan Pathfinder
I have led switchbacks in the front of my car and they blink fast which I understand so I went to add led bulbs in the brake lights and now they blink slow but all my lights blink including my parking and other turn signal. I put a resistor on them and they did they same thing. Then I took out the led brake bulbs and they still do the same. Any ideas?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Get rid of the load resistor(s) and replace your flasher unit with an electronic flasher. You can get this electronic flasher from Advanced Auto Parts for $10.39 before tax if you order online using discount code M20 and pick-up in store.
edogg27
Ive done some searching and the swap looks a little difficult on accessing it. Is this tru?
Towncivilian
You'll most likely need to remove the lower instrument panel cover to access the flasher unit easier, but this isn't terrible. See this post for details.
04LEMASS
Car: 2004 Nissan Pathfinder LE Platinum
-K&N Air Intake
I was able to do it without removing the panel i just found the flasher and yanked it out wasnt that bad.
edogg27
where did u go in though. like did you just take the steering wheel cover off?
Towncivilian
This is where the flasher unit is:
It's the little black box in the center of the picture.
edogg27
This has the lower panel removed. Is there anyway to do it without that?
And is the unit that triggers the door lights in this pic? I forget what it's called
Towncivilian
Yeah, 04LEMASS says it's possible to swap it out without removing any panel. I've never tried it.
Smart entrance control unit? Nah, it's not in that pic. See EL-35 for its location in your Pathfinder.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
I replaced the flassher on my '01. It's tight, but you can reach up there and pop it off, It's not a standard mount that you can get at the auto parts store.
I ended up mounting a parts store flasher to plastic panel below the flasher.
Chuck
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
I bought one electronic flasher for LED. If I use this flasher, will it affect the regular turn signal bulb operation? I haven't bought the rear turn signal LED bulbs yet. It's not so easy to find a bright enough LED but still not too big size so it fits in the housing.
Camelfilter
Car: 1999.5 Pathfinder SE
2009 Titan Pro 4X Crew Cab
I have regular lamps in front turn signals and leds in rear turn signals. My turn signals flash ok with the led compatible flasher unit. They flash a little bit faster than with the original flasher unit, but not "hyper" flash.
QX4ME
11 MB C300 Sports
06 Honda Odyssey
Camelfilter wrote:I have regular lamps in front turn signals and leds in rear turn signals. My turn signals flash ok with the led compatible flasher unit. They flash a little bit faster than with the original flasher unit, but not "hyper" flash.
Thank you for the reply. did you take panel off? I tried not to take panel off first but seems no way I could find the original flasher.
edogg27
I removed mine today i took off the entire panel. All you have to do is take off the kick pannel by the door it has one bolt and clips then that will reviel a screw take that out then on the side closer to the radio theres another screw pop that off and give it a tug, oh and remove the undercover of the steering wheel 2 screwes then u will see a metal brace type thing ur looking for a black little box take a screwdriver pop it off and plug the harness into your new flasher. I mounted mine to the metal part with gorilla tape. Probably took me a total if 25 mins from start to finish
QX4ME
11 MB C300 Sports
06 Honda Odyssey
edogg27 wrote:I removed mine today i took off the entire panel. All you have to do is take off the kick pannel by the door it has one bolt and clips then that will reviel a screw take that out then on the side closer to the radio theres another screw pop that off and give it a tug, oh and remove the undercover of the steering wheel 2 screwes then u will see a metal brace type thing ur looking for a black little box take a screwdriver pop it off and plug the harness into your new flasher. I mounted mine to the metal part with gorilla tape. Probably took me a total if 25 mins from start to finish
Thanks a lot I will do it next weekend. You mounted your new flasher NOT in the same place because of its size or else?
edogg27
It isnt the same mounting type. I just left the old one monted there and taped the other one to the metal. Brace. Hardest part of the whole thing is getting the screwdriver in there to pop off the wire harness haha
Camelfilter
edogg27 wrote:It isnt the same mounting type. I just left the old one monted there and taped the other one to the metal. Brace. Hardest part of the whole thing is getting the screwdriver in there to pop off the wire harness haha
That was good thinking just leaving the original mounted! I popped mine off and put it with my spare bulbs and stuff...hopefully I won't forget what I did with it if I ever want to find it.
I too just taped the new one onto the metal brace.
Tip: if u are trying to figure out which is the flasher relay, turn your ignition untill you can turn on the flashers...you can hear it and feel it clicking.
-I needed to remove the plastic same as edogg mentions. Some folks may be able to get to it without though...
QX4ME
11 MB C300 Sports
06 Honda Odyssey
OK, very interesting. As Camelfilter said his flasher flashes a bit faster. I tried to open the flasher plastic cover but the locking tabs stopped me. Otherwise I might be able to find where the adjustable time constant is.
QX4ME
11 MB C300 Sports
06 Honda Odyssey
Towncivilian wrote:This is where the flasher unit is:
I removed the panel but still have difficulty finding the flaser unit. Is it on the right side of steering wheel, if I sit in driver seat and look at the footwell? There are a few connectors but nothing looks like a flasherunit.
I turned on turn signal. Clicking sound seems to come from everywhere maybe due to echo?
Chuck Tribolet
'87 Chevy Corvette
Start the flasher flashing. Put your finger on anything you think might be it. You'll feel it. IIRC, it's black and has three wires going
to it.
Chuck
QX4ME
11 MB C300 Sports
06 Honda Odyssey
Wow it's been nearly two years since I tried locating this flasher. Today I encouraged myself and finally found it behind the fuse panel/box. The flasher is in a very difficult place. I forced it out and taped the electronic flasher around the wire bundle, then removed the unnecessary 6 Ohms power resistors across each LED. It work well except I noticed that depending on when I return the turn signal, the new flasher sometimes clicks one more time than the LED.
