Flyers28 »
https://forums.nicoclub.com/flyers28-u217208.html
Sun Sep 15, 2013 5:36 am
So I've had my LEDs installed for several months now and no issues. Get in my car last night close the door and notice my map lights and dome lights are still dimly lit after the door has been closed. The only way to turn them off is switching the switch by the lights to the off position. Before i waste my time and start sticking volt/ohm meter on every connection point i wanted to see if anybody has experienced this and found a fix. Its been getting colder these past few days especially at night, my concern is moisture is building up somewhere at a contact point causing current leakage to the bulb. Thoughts?
