These will work but there is a chance you may have to switch the polarity on the front map LEDs. I went with the DIY 6-LEDs for the map & domes and ordered the BA9s and 31mm bases that they plug into. My reasoning is that for the fronts it's much easier to swap the pins on the DIY connector than it would be to completely disassemble the LED assembly and have to resolder connections. I just wanted to have matching rears so I got them all.sunoco wrote:I am trying to put together a list of current part numbers from V-LEDS to do the interior on my 07 M35.
Do you guys think these lights will work and provide enough light?
Front dome (map) - http://www.v-leds.com/Exterior-LED/Corn ... 00865.html
Rear dome (map) - http://www.v-leds.com/Interior-LED/Dome ... 08258.html
Front door - http://www.v-leds.com/Exterior-LED/Corn ... 81039.html
Rear door - http://www.v-leds.com/Exterior-LED/Corn ... 81039.html
I believe this covers everything on the interior except the footwells. If you arent going to replace the black lens cover with a clear one then its not worth buying the bulbs. Anyone have any changes / suggestions? Thanks!!!!
I remember that. They did it twice, during the week. I missed them bothrelentless1 wrote:They're probably out of stock for a lot of the good stuff since they did the 50% off promotion for 20 minutes a week ago.
I just got my order from v-leds with those 4 bulbs listed above and... none ligthing up for some reason! They all 4 do looked like direct swap, "plug and play things" to me but not in my casesunoco wrote:I am trying to put together a list of current part numbers from V-LEDS to do the interior on my 07 M35.
sunoco,
if you did get yours in, worked for you? anyone have any suggestions?
