LED in the instrument panel
clemson99
Car: 93 Infiniti J30 Green (daily use)
06 Infiniti M35X Gray (week end)
I saw that the instrument panel light bulb is a 194. Has anyone else upgraded to a LED 194 bulb? If so how do I remove the panel to get to the bulb?
jdurrty
Car: j30
First remove the two screws that hold in the dash piece right above the steering wheel that houses the dimmer switch and cruise control buttons. Remove this trim piece. Next remove the screws that hold in the black bezel that sits in front of the cluster, I believe there are four total. Now remove the screws that hold in the cluster, disconnect the wiring in the back and presto! you are done.
clemson99
Thanks I'm getting some blue high power LED bulbs in next week and want to test them out in my J. :naughty:
yodawill2000
Car: 94 Infiniti J30
I have them on the interior courtesy lights and they look great !
:gapteeth:
jdurrty
Car: j30
Note that the gauges themselves are green, not just the light bulbs. So installing blue lights might end up giving you a teal color. Just a heads up
driverdriver
Car: NICO's longtime resident Canuck!!!
Post pics when done.
JDM_J30_tx
Car: Pearl White 96' Infiniti J30
I actually did this as l had extra led bulbs. When l removed the bulbes they had a green cap over the bulb. As long as the led bulb shine like a standard bulb you will be fine.
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
make sure the LED bulbs have a decent spread or else it will not light up the full gauge cluster
clemson99
Finally got the blue LED's installed in the dash :naughty:
EriCCirE
Car: 1993 Infiniti J30
clemson99 wrote:Finally got the blue LED's installed in the dash :naughty:
Got rice?
clemson99
I'm sorry I don't quite understand your statement.
yodawill2000
"Ricer" is those you mod up honda's and such. As in the giant fart pipes for exhaust. lol
I think it looks pretty good myself.
I have blue led's in all my inside lights, except for the map light.
clemson99
Thanks Yoda. I think the blue looks good also. No rice here...pure Green 93 J30
Yes that is a M35x in the back ground
yodawill2000
That's a Beauty !!! Mine was almost that clean till a Hailstorm came through.. :gapteeth:
clemson99
Thanks. I'm restoring her slow. Getting seats and doors redone, upgrading the stereo, and getting the sunroof back in working order. This forum has really changed my mind on my J.
JP72
I personally like the blue look as well. I replaced all my interior lights with green led's ..black on black and glowing green! And if you really like to be called a ricer, install blue halos to match. I love my green ones :gapteeth:
nemo44
Car: 1993 infiniti j30
hey clemson99 what info do you use to order the led bulbs? i really want them.. thanx
