even when you have a few light going 24/7 its not that bad.TroubleBound wrote:You goan needa contact AZHitman or one of his staff before you be slinging prod on the boards. And this seems like a weird place to be advertising such products. Less energy is good, but is it still so much that your power bill will see a suspicious jump with numerous lights installed?
The one that John Voight sold to George Costanza?Jesda wrote:I'm 90% sure this guy drives a Chrysler Lebaron coupe.
24 hour use has been proven to be inefficient. An 18/6 schedule should be the max.Zydeco wrote: even when you have a few light going 24/7 its not that bad.
There are many ways to cool a light, but heat/humidity is definitely a constant battle.PoorManQ45 wrote:
One of the huge problems with MH though is the heat output. Active cooling is required to prevent the plants from roasting and the ballasts from having a shortened life span. This isn't too bad, but considering that this can use an extra ~100+ watts of power it could be significant in a large operation.
PoorManQ45 wrote: Two winters ago I used a 125w Florescent in a MH stippled reflector to start two 72 plant trays of everything from peppers, lettuce, tomato, beans, etc. I got the plants to about 6" and then moved them all outside. After a week I planted them. That batch grew pretty well, but didn't produce as much as the plants that were started from seed at the same time as the 6" ones were being planted. Something about the transition didn't bode well for them.
Disclaimer: I know nothing about this subjectbreadbox wrote: You can buy 8-10 bulb t5 floros that are pretty decent and they generally stay cooler and provide a decnt coverage, perfect for winter gardens setup in the kitchen.
That's the thing tho, winter gardens are insanely easy to maintain.PapaSmurf2k3 wrote:breadbox wrote:
It sounds like these MH bulbs that skipjack over there was talking about would be a pretty good match for the northern states for your winter growing. If the only downside is they put out a lot of heat, then it wont matter, seeing as how you are heating your house anyway.
I did something similar with my garden last year. I started half indoors and got them to ~6-8" and also planted seeds in the soil. The baby plants were moved outside at the same time I planted the seeds. The seed plants took a little bit longer to mature, but ultimately ended up producing more than the plants I started indoors. I think it was the soil because I used compost and s*** when I started the seed plants outside vs the indoor plants. I can't wait to start planting again this year!PoorManQ45 wrote:Two winters ago I used a 125w Florescent in a MH stippled reflector to start two 72 plant trays of everything from peppers, lettuce, tomato, beans, etc. I got the plants to about 6" and then moved them all outside. After a week I planted them. That batch grew pretty well, but didn't produce as much as the plants that were started from seed at the same time as the 6" ones were being planted. Something about the transition didn't bode well for them.
frapjap wrote:I did something similar with my garden last year. I started half indoors and got them to ~6-8" and also planted seeds in the soil. The baby plants were moved outside at the same time I planted the seeds. The seed plants took a little bit longer to mature, but ultimately ended up producing more than the plants I started indoors. I think it was the soil because I used compost and s*** when I started the seed plants outside vs the indoor plants. I can't wait to start planting again this year!PoorManQ45 wrote:Two winters ago I used a 125w Florescent in a MH stippled reflector to start two 72 plant trays of everything from peppers, lettuce, tomato, beans, etc. I got the plants to about 6" and then moved them all outside. After a week I planted them. That batch grew pretty well, but didn't produce as much as the plants that were started from seed at the same time as the 6" ones were being planted. Something about the transition didn't bode well for them.
hey Hey HEY!!! Let's not be ragging on my LeBaron convertible turbo..... I mean, it might be running again someday.PapaSmurf2k3 wrote:turbo?
