Led for the rear license plate lights
KoMikeey
Car: 2007 M45 S, Aero kit, Diamond Graphite, Uprev, Injen CAI, G37 sport vlsd differential swap, Full custom exhaust (removed secondary cats) into an x pipe through the megan exhaust.
hey guys im trying to replace my rear license plate light into a led do you know what size the led lights have to be?
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
they are 168 bulbs
Craig
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
I'm using 194 led replacements. Work fine.
KoMikeey
does it look clean like the lexus led lights? i dont want it to look like the cheap blue lights that go on honda's no offense to anyone who has that LOL
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
i used these on mine, but i found a seller on ebay that sold a pack of 20 and used it for my doors, footwell, and trunk lights
http://www.ebay.com/itm/2x-White-1206-S ... 50&vxp=mtr
DeanM45
Yep, those look like the ones I used. Clean white, no blue!
KoMikeey
do you have pictures?
KoMikeey
lol whatever guys i just bought its only 5 bucks. but thanks for the help guys!!!!!
06M4.5
Car: 2006 M45
KoMikeey wrote:do you have pictures?
All led's in white:
DeanM45
Hey Freddie,
Which bulbs are you using for the turn signals?
06M4.5
Car: 2006 M45
I don't remember as I did them about 2yrs ago.
but they are the oem type bulb with maybe 24 smd (on each bulb) led's in white. I think I had to remove the tail light to install them.
GQM45s
These are what I bought for my turn signals, they are SUPER bright, i have the hyper flashing tho, but i dont know, i kind of like it, not sure if you are up for it.
http://www.ebay.com/itm/Car-Xenon-White ... 81&vxp=mtr
DeanM45
Wow, those fit? Didn't think there was enough room for those. A resistor should not be hard to install as I don't care for the hyper flash, I like things s-l-o-w LOL.
06M4.5
Car: 2006 M45
hyper flash happens only when you use the turn signal (which I like very much). using the emergency lights flash normal.
the problem with using resistor is that they run too hot!!!
DeanM45
The hazards do not have the hyper flash because it is a balanced load with all the lights flashing. Yes, the resistors do run hot, that is their function. There are ways to minimize that though.
06M4.5
Car: 2006 M45
look at fender vents in hyper flash mode:
http://www.youtube.com/watch?v=__gDftUSWOQ
only way to keep heat down on resistors is to mount them on metal, I had to install 6 of them in my last BMW because of cel light on dash. I try my very best not to use them anymore.
GQM45s
DeanM45 wrote:Wow, those fit? Didn't think there was enough room for those. A resistor should not be hard to install as I don't care for the hyper flash, I like things s-l-o-w LOL.
it does actually, i was surprised myself, I also have them in my front turn signals as well, they almost touch the clear housing so i am pretty happy with it, plus its in a large area so it wont overheat as bad, My front turn signals have a about an inch gap between the clear housing and the tip of the bulb.
My car will be LED out, till i can clear out the side markers - bought some 06-07 side markers cause its not one stupid assembly on the 08+
KoMikeey
now that i ordered it, do you guys know how to change out the bulbs? from the trunk or just pop the plastic covers on and swap them out?
atlM35
Just remove the inside liner of the trunk lid.
Takes less than 5 minutes total.
GQM45s
No need to take off the interior, if you open your trunk, next to your assembly you will see a plastic piece, normally body color matched. You pop that off to access the bolts, be careful as the plastic piece has clips when you pull them off, you might break them.
screw off the bolts to access the assembly, once you have those bolts off, there are clips behind the assembly as well. all you have to do is pull it off.
Once assembly off, twist off the cap for the turn signals, you will see the bulb, twist to unlock. Once you unlock it, you may want to look in the hole of the assembly to see if the cable is tucked underneath anything (mine was, letting you know from my experience) Grab a thin screwdriver or whatever you can find to untuck it to give you some slack. Once you have enough slack you can pull out the bulb, swap and then reverse back to normal. ( i didn't tuck the cable back it, didn't care to)
atlM35
You can do that... or you can just undo the clips on the trunk lid liner and access the bulbs directly.
No bolts to remove or chances of breaking any clips. Take your pick, both methods work.
