The Hoens produce enough good lighting...I've had them on for over two years and still going... For me, it's an easier alternative than going full HID fogs...here's a shot that I took a few nights ago. Hopefully this helps youAltered wrote:CPJ do you find those Hoens to be somewhat dim? I tried them in my Altima and took them back out because they weren't bright to my liking.
thanks! they do well for me... it's rated at 55w.Altered wrote:Those actually do look pretty good...what wattage are you using?
for the fog lights, yes... just remove the lower engine splash guard (some screws under the front bumper) and you can access the back of the fog light housing... simple plug and play.Logan00 wrote:Are the H11 bulbs a direct replacement for our factory bulbs that will not require anything else to replace them?
I assume you are referring to the plastic piece around the fog lights in the bumper? If that is all it takes that would be perfect.CPJ LB wrote:for the fog lights, yes... just remove the lower engine splash guard (some screws under the front bumper) and you can access the back of the fog light housing... simple plug and play.Logan00 wrote:Are the H11 bulbs a direct replacement for our factory bulbs that will not require anything else to replace them?
