LED DLR Hook up.
All things Altima Coupe.
stevewaclo
Car: '08 Altima Coupe SE 6sp 105k
Hello all,
Picked up two 12" LED strips I want to add under the headlamps.
Looking for a easy place to find a switched, 12V line up in the front.
Suggestions?
Best wishes.
mmkeller
Car: 2017 Maxima SR
2009 Murano SL
Spliced mine into the park lights, it works and no switch needed in the interior.
stevewaclo
Lookin' good, but not really DRL if they only come on with the parking lights. I want them to be on a switched 12V that comes on with the ignition, turning on the LED's any time the car is running, not just with PL's.
Don't have a schematic and was hoping someone had located a switched, 12V source somewhere near the front. Suppose I can use a pin and a test lamp and start searching :-).
Thanks for the suggestion!
stevewaclo
Page 40 of this document:
http://www.nicoclub.com/FSM/Altima/2008/pg.pdf
Shows E228, a "Daytime Light Relay" as part of the Front End Module Harness. Did Nissan install this in anticipation of adding DLR's to later year Altima's ? My "08 does not have DRL's and I'm wondering if you folks with later models do have them. Before I go out and start poking around (hey, I'm a lazy guy :-) maybe someone knows if that relay even exists on my car. Sure would solve my problem.
Anyone know?
Thanks.
stevewaclo
Stumbled upon this study during my research:
http://www-nrd.nhtsa.dot.gov/Pubs/811029.pdf
Short version: no statistically significant benefit in the US. But nothing is ever simple and numerous European studies show reduction in crashes from 5-27%.
My motivation is purely cosmetic :-).
bmaxeo
Car: Nissan Altima Coupe 2.5s
I just spliced mine into the parking lights , and it worked great also.
BTUT5
Car: 2010 Metallic Slate Altima Coupe 2.5 6MT
bmaxeo wrote:I just spliced mine into the parking lights , and it worked great also.
Yeah same here but I don't see why you can't go testing with a pin and test light. I think most of us with DRL's have used the parking lights.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Being the first guy to ever do this to the coupe...I agree with everyone else...splice it into your park lights and call it a day!
adrianjuaneli
In these aspects, We must consider the high quality of LED strips which will help us to give more brightness while compared to the normal one.
optical systems design
parabolic light reflector
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
dangeris wrote:Being the first guy to ever do this to the coupe...
You so speeeeecial!
J Russ
Car: 2016 Audi S5 - Many Mods
Well I wouldn't call him first… However because of the difficulty to hook them up, I hired someone at a dealership I used to work at to do it. These are super bright, brighter than Audi LED DRLs, I keep my lights in auto mode, and when the headlights come on, these dim down.
DJ_B_Easy
J Russ wrote:Well I wouldn't call him first…
I would. Pretty sure D built his DRL set-up and retrofit in late 2008/early 2009? I was just teasing him.
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
I wish I had a sweet set of Daytime Lunning Rights.
